Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Bearing loads/ shrinking pressure › Reply To: Bearing loads/ shrinking pressure
angelo niola
Hello Akshay, thank you for answering.
At the beginning I selected the "bearing load" command and set 23358 N as the value in "vector". So now I should assign a new coordinate system (or even keeping the default one), choose the bearing load command and assign my value 23358 N , on the radial component (in my case y), correct?
Thank you again,
Angelo
