Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Multizone meshing issue › Reply To: Multizone meshing issue
adave12
Oh ok, I think I finally understand what you meant to say. Yeah, that would create several fluid domains or bodies. I will give it a go. Thank you so much. Additionally, due to the angle of the flow promoters or vortex generators, the leading tip edge is almost in line or even further in than the tail of the preceding promoter. Again, thank you so much for all your help
