Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Meshing surface body › Reply To: Meshing surface body
mjmiddle
Sorry, but SpaceClaim 2023 R2 does not let you create mixed dimension blocking (nor 2024 R1).
You can use assembly mode in workbench. In one system, you can "suppress for physics" or delete the surface bodies, and the other system supress or delete the solid bodies. Combine the Model cells to a downstream Model cell to use assembly mode.
If this is for a CFD analysis, you can use "Mesh" systems rather than Mechanical Model systems.
