Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › question about define joint in dynamics analysis with ANSYS mech › Reply To: question about define joint in dynamics analysis with ANSYS mech
January 31, 2024 at 7:09 pm
In a harmonic analysis you could specify a stiffness equal to LOAD/20 mil) for the frequency you are solving for, but in general, no, you can't specify isolator properties as a function of frequency. The LOAD is probably a combination of damping and stiffness forces so that makes it even more ambiguous how to use these curves.
