Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical help, dielectric slab waveguide › Reply To: Lumerical help, dielectric slab waveguide
Hi Marton,
Good question. Firstly, since you are looking at slab waveguide I believe you are concerned only about the thickess of the layers in one direction (y-direction here). The other two directions can be considered uniform. So, you can use a 1D FDE solver, something like:Â
setnamed("FDE","solver type","1D Y:Z prop");For automaticaly adjusting the FDE thickness here is what I have done in the past, although it is not very sophisticated, it works. You can go to the model tab:
Then go to "Setup"-->"Script", then you can paste the following script or something similar as shown below:
y_min = getnamed("structure group::layer_1", "y min")-2e-06;
y_max = getnamed("structure group::layer_5", "y max")+2e-06;
setnamed("FDE","x",0);
setnamed("FDE","y min",y_min);
setnamed("FDE","y max",y_max);Â
Here, what the script does is calculates the minimum (y min) of the first layer and (y max) of the 5th layer, subtracts 2 um from y min and adds 2 um to y max. Then makes them the y_min and y_max of the FDE. So, everytime the layer thickess (d1 through d5) change, the y_min and y_max of FDE will change.Â
Amrita
