Ansys Learning Forum Forums Discuss Simulation Fluids No convergence In Mesh Independency Study of Basic Jet in Crossflow Setup Reply To: No convergence In Mesh Independency Study of Basic Jet in Crossflow Setup
Please can you post some results? If you plot with node values off it'll help show how well the mesh refinement looks. Minimum can also be a misleading measure: in theory the minimum velocity on that line could be zero as it picks up the wall velocity. If you overlay the xy plots from the line how do they compare?
