Ansys Learning Forum Forums Discuss Simulation 3D Design Meshing surface body Reply To: Meshing surface body
Govindan Nagappan
Hi Michal,
Why do you have 2 "model" tabs? Can you make sure, you remove one. Check in project schematic using View -> Files and see if there are multiple scdoc files associated with this analysis system. Make sure you have only one geometry associated with the analysis
Also, see if switching element order helps
