Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modelling effect of vapor absorption in energy exchangers › Reply To: Modelling effect of vapor absorption in energy exchangers
SRP
you can indeed modify the energy equation using User Defined Functions (UDF) to include the effect of phase change of vapor on the performance of the system.
You can also check forum discussion: Multiphase flow properties (ansys.com)
Eulerian model for evaporation and heat exchange (ansys.com)
Hope this helps you.
