Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Update failed for mesh component in Fluid flow (Fluent). › Reply To: Update failed for mesh component in Fluid flow (Fluent).
V.P
Hi Prashant,
Can you try this, open the mesh editor, right-click on Mesh in the outline tree, and Click on Update. Check for the warning message, which might give a more clear idea of what might be the issue.
