Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Does Maxwell have transient thermal analysis with a motion setup? › Reply To: Does Maxwell have transient thermal analysis with a motion setup?
January 31, 2024 at 12:54 pm
First of all, thank you for your response. I am asking to confirm if I understand correctly. It seems that I cannot use Icepak(transient) and Maxwell(transient) two-way coupling to observe the temperature change of a moving object. In this case, what would you recommend using? I need to add temperature change to the motion obtained from transient analysis in Maxwell. Is Workbench Maxwell and transient thermal coupling suitable for this study? I would appreciate it if you could provide information. Best regards.
