Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient heat transfer time step data input or data import › Reply To: Transient heat transfer time step data input or data import
n2390n
hi sir:
My case involves a Pulsed laser, so massive heat flux occurs only for a brief period (15 picoseconds)
here is one of my case recipe.
and I already finished get some data I need,
However, the process is very intricate (for example, setting each step’s end of time & timestep, etc. to make the temperature curve more perfect)
You mentioned above and suggested that I might be able to use Excel to replace my method of inputting options one by one. I am very interested in this and would like to learn from you.
Below is a picture of how I set the timestep, with the red boxes indicating each place I need to set.
thx again
