Ansys Learning Forum Forums Discuss Simulation Photonics Frequency Domain Field Profile Monitor on Plasmonic PA Reply To: Frequency Domain Field Profile Monitor on Plasmonic PA
Muhammad Irfan
Thank you for your detailed reply. I made the changes in dx and dz with mesh override settings and results have been greatly improved. But Still I am unable to make material distinction in the E-field confinement window. Is it because layers are too thin? Please note that I am using layers of thickness 0.345nm and 4nm in the design. Also, please guide how to keep field profile intensity bar between 0-1 range, in my case it shoots off to 29 high and low at 0.0912. When I manually adjust the value, the intensity of colors deteriorates.
