Ansys Learning Forum Forums Discuss Simulation STEM The mesh generation did not complete due to poor quality elements or incorrect Reply To: The mesh generation did not complete due to poor quality elements or incorrect
Aniket Chavan
That could be the exact reason for failure. The quality of stl data might not be adequate to create clear solid, so before using convert facets to the solid body you will need to use STL cleanup tools available in SpaceClaim, which is not only soothing but there are multiple tools such as, check facets, auto fix etc.
-Aniket
Forum Rules & Guidelines
