Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › “Time step is too small” › Reply To: “Time step is too small”
pourrezamh
Thanks Chris for the hints! The erosion control did the trick, but I ended up with a bloody and exploded model. You were right; the total velocity is too high! I try to reduce the speed first, then play around with the boundary conditions.
