Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical FDTD Sweep Function › Reply To: Lumerical FDTD Sweep Function
Amrita Pati
Hi Josh,
This is unusual. What happens if you do a single simulation for this last sweep paramater? That is change the radius to 0.15 um, and run a single simulation. Also, would you be able to share a screenshot of the Sweep Utility, where the parameters are set up.
Amrita
