Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical help, dielectric slab waveguide › Reply To: Lumerical help, dielectric slab waveguide
January 30, 2024 at 5:52 pm
 We can do a sweep using the Sweep Utility:
Once you edit the sweep to set the parameters for sweep. I would recommend you to have a look at this article to set up the sweep:Â Parameter sweep utility.
In this case the parameters will be the thickness of the layers, whichever layer/layers you would want to sweep. For example, if you just want to sweep d3, you can select it as a parameter as shown below:
Then you can set appropriate ranges for each parameter, add the result that will be saved after each sweep, like the effective index etc.
Amrita
