Ansys Learning Forum Forums Discuss Simulation Electronics Automation of Maxwell iterations with Workbench Reply To: Automation of Maxwell iterations with Workbench
DELI
Hi Adem, you can assign motion setup on the moving object in Maxwell and run a transient analysis, the torque results could be automatically calculated in Maxwell. Or you can define a parameter of the angle in Maxwell and run parametrics analysis with static solvers, the torque result could be calculated in Maxwell.
