Ansys Learning Forum Forums Discuss Simulation Fluids Design Modeler for Fluid Simulaton Reply To: Design Modeler for Fluid Simulaton
Anthony Bowers
This al all very helpful thank you. I applied some advice and it partially worked. I was able to he get hexidomanint cells for the individual Flow conditoenr holes, but now the other section is giving me issue.  What do you guys suggest for meshing this part? As you can see by the red circle there is a very very small gap between this edge and the flow conditoner edge..
