Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical FDTD Sweep Function Reply To: Lumerical FDTD Sweep Function
Joshua Chen
Hi Amrita,
Yes, only the last point is breaking the trend. This is a 2D parameter sweep ("sweeping" height as well, though for only one value of height = 1.3um). The only variable I'm changing in between sweeps is the number of points in the sweep.
When I run it for three points, the last point is again a different value, different from when there were 4 points or even more points.
Thanks so much!
Best,
Josh
