Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Variable density for solid object › Reply To: Variable density for solid object
January 30, 2024 at 10:49 am
Alberto
It is a solid zone, obtained through a boolean subtraction where the tool is the solid and the target the fluid volume.
Yes it is attached to the aluminium material as user-defined input
