Ansys Learning Forum Forums Discuss Simulation General Mechanical User defined results Reply To: User defined results
erik.kostson
It is called USUM
also see the worksheet results for names.
/forum/forums/topic/worksheet-result-ansys-mechanical/
Finally check out also the identifiers as they can be used for creating user define results – see here for an example:
https://www.padtinc.com/2011/09/01/using-the-identifier-for-mechanical-post-processing/
All the best
Erik
