Ansys Learning Forum Forums Discuss Simulation Photonics Transient Heat Using FDTD Pabs as Import Heat Source Reply To: Transient Heat Using FDTD Pabs as Import Heat Source
ayoub.naoui
Hi Niki,
Thank you for your reply. The problem for me in using the bondary condition to create temperature is that the absorption in my rectangle is not uniform. Whereas using a power source in my rectangle gives an almost uniform heat distribution.
Kind Regards,
Ayoub
