Ansys Learning Forum Forums Discuss Simulation Fluids Calculation of a centrifugal pump in fluent Reply To: Calculation of a centrifugal pump in fluent
Satish Patange
There can be various reasons for continuity eqn divergence.
Could you give more information about your physics setup: What multiphase model are you using? Is the gas modeled as compressible? What BCs are you currently using? Are you solving this as steady state with MRF for the rotor-stator?
A few screenshots of the setup will be helpful showing the setup.
In the cross section plot with the methane vf, where are the inlet, impeller and outlet? Also include a picture of the mesh on this plane.
