Ansys Learning Forum Forums Discuss Simulation Fluids Variable density for solid object Reply To: Variable density for solid object
The wall must be a solid material, and the flowing volumes are fluid. So, the UDF will hook to the solid material and then the solid is assigned to the wall.
