Ansys Learning Forum Forums Discuss Simulation Fluids Variable density for solid object Reply To: Variable density for solid object
Alberto
Ok, but i don't have the aluminium as material, i've load this udf file and fluent accept it as material property. I want density = 40 when i'm moving over the object surface where the cell are susbatially 2D, then i want 430 when their 3D. This is the way I'm trying to set material properties. Does it work?
