Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Variable density for solid object › Reply To: Variable density for solid object
OK, but you're setting a material property. For a solid (or wall) that's the solid material type, default is aluminium. So if the solid zone is of a certain thickness there's no need for the gas property.
