Ansys Learning Forum Forums Discuss Simulation Fluids How to add a spring device between the two structures of AQWA, so that it will r Reply To: How to add a spring device between the two structures of AQWA, so that it will r
Shuangxing Du
I am sorry that it may not possible to set the current to change over time in Aqwa.  But you may run several time durations, the current are different between different durations.
