Ansys Learning Forum Forums Discuss Simulation Fluids How to add a spring device between the two structures of AQWA, so that it will r Reply To: How to add a spring device between the two structures of AQWA, so that it will r
1317794602
Hello, my wind speed in AQWA was imported into an Excel file, and the wind speed has a duration of 10800 seconds. As wind speed can cause changes in flow velocity, how should I set this flow velocity based on this wind speed
