Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem defining the surface of the crack in the solid › Reply To: Problem defining the surface of the crack in the solid
January 29, 2024 at 8:58 am
I think the problem is that I have not correctly established the connections between the crack plane and the surface of the solid. I would appreciate your help with the contacts issue because it is too advanced knowledge for me.
