Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › creep analysis_ benchmark the data › Reply To: creep analysis_ benchmark the data
January 29, 2024 at 7:24 am
hi,Â
yes i have done curve fitting using modified time hardening and Generalized exponential form. if i use those constants and run the simulation i didnt get the exact deformation as from experimental value. so what are the changes need to change or modify. and can you recommend how to do tertiary creep analysis(using APDL or any other software) with this inputs. and what are ways to benchmark and tertiary analysis method
