Ansys Learning Forum Forums Discuss Simulation General Mechanical How to define self-weight of a structural body in static study? Reply To: How to define self-weight of a structural body in static study?
peteroznewman
Hello Sara,
Gravity acts in the direction chosen on each element in the model individually. Only if the direction you want gravity to pull is not aligned to a global axis would you need to create a local coordinate system at the desired angle.Â
