Ansys Learning Forum Forums Discuss Simulation LS Dyna D3 failure parameter in *MAT_015 (JOHNSON_COOK) Reply To: D3 failure parameter in *MAT_015 (JOHNSON_COOK)
Armin
Hi Rong,
Could you include the definition of Johnson-Cook failure criterion from the paper you mentioned above?
It is possible that, in the paper, D3 is multiplied by hydrostatic stress rather than pressure. Pressure is simply the negative of hydrostatic stress and that may explain the difference.
