Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Simulate two ports of MMI › Reply To: Simulate two ports of MMI
minusunny
I am using SWG based MMI.  Can i use EME? I used FDTD for that. Can i use the same s parameter extraction for FDTD? Also, i did an s parameter sweep in FDTD and saved the sparameter value in lumerical format and exported it to the interconnect i got this error:
SPAR_1: Fitting for '256' coefficients...
SPAR_1: Error in fit is '0.00109188'.
SPAR_1: Calculating filter coefficients at '1.931e+14' Hz ...
SPAR_1: Error in fit is '0.00171933'.
SPAR_1: Error in fit is '0.0020334'.
SPAR_1: Error in fit is '0.00203526'.
Is it because i did not use the right format to export?
