Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical FDTD Sweep Function › Reply To: Lumerical FDTD Sweep Function
Amrita Pati
Hi Joshua,
You are correct, the sweeps should run independently. Are these single sweeps (that is are you only sweeping the radius)? Is there any chance that another parameter is being swept along with the radius? Also I believe, the last point is the one breaking the trend? All the other points look accurate, is that so?
Amrita
