Ansys Learning Forum Forums Discuss Simulation Fluids Material setting question Reply To: Material setting question
If you use fixed values you may want to set them at the condition you want to model (eg 90C & 28bar). Otherwise whilst the model will be correct for the values set you may find they're different to what you expect.
