Ansys Learning Forum Forums Discuss Simulation Fluids How to add a spring device between the two structures of AQWA, so that it will r Reply To: How to add a spring device between the two structures of AQWA, so that it will r
Shuangxing Du
The force and moment act on the hing point as Joint Forces, these force/moment provide the force and moment as Structure Force, Articulation Sum Only with respect to the COGs of the linked structures. As shown below both the joint force and the articutation sum force on the linked structure can be displayed in Aqwa Workbench.
