Ansys Learning Forum Forums Discuss Simulation Fluids Material setting question Reply To: Material setting question
OK, so 28-29bar at around 90C.
You need to decide if the density difference is sufficient to need to use a variable density (ideal gas) or fixed density at the mean temperature & pressure. The latter will be much easier to model.Â
