Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to add a spring device between the two structures of AQWA, so that it will r › Reply To: How to add a spring device between the two structures of AQWA, so that it will r
1317794602
Hello, I have created a hinge joint. When analyzing the force, how can I determine the direction of XYZ? Is this force direction in the original coordinate system(FRA)
