Ansys Learning Forum › Forums › Discuss Simulation › Materials › Importing a .xml file into the Engineering Library of materials › Reply To: Importing a .xml file into the Engineering Library of materials
January 25, 2024 at 8:58 pm
The material .xml file from Comsol might have a different structure or different materials property names, than materials records in Ansys. Maybe open the .xml file from Comsol into a text editor and compare to an exported Ansys .xml file. You can find some examples and explanations in the following links:
- https://www.padtinc.com/2011/10/12/importing-and-exporting-ansys-mechanical-loads-as-xml-files/
