Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FLUENT MultiPhase – floating point exception 6hrs into calculations › Reply To: FLUENT MultiPhase – floating point exception 6hrs into calculations
January 25, 2024 at 2:13 pm
Yes. And in steady you'll probably finish up with gas slugs in the outlet pipe. Degassing may help, but it's really designed for a stable free surface condition as there's not a pressure value set. Boundary conditions here aren't straightforward as you may find you need to balance the gas vent against the liquid outflow.
