Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient or Explicit for high strain rate simulation › Reply To: Transient or Explicit for high strain rate simulation
Ram Gopisetti
Hi Pranshu,
What is the actual time you are considering?
Since the strain rate is high and no time information is given in your description, we cannot recommend you
Generally, using the explicit is good, but time is important. Both methods account for time, inertial, and damping effects, but the computing framework will change (implicit vs. explicit).
cheers, ram
