Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT MultiPhase – floating point exception 6hrs into calculations Reply To: FLUENT MultiPhase – floating point exception 6hrs into calculations
Samantha Fedorenko
Thank you Rob for your guidance. I now see that the mesh needs refining in the centre, as there is a fairly rapid velocity change in the centre.
I see the auto range was very poorly chosen for turbulence. The results are better with manual scaling.
