Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FLUENT MultiPhase – floating point exception 6hrs into calculations › Reply To: FLUENT MultiPhase – floating point exception 6hrs into calculations
January 25, 2024 at 11:02 am
Here's some results of teh single phase results at the cycling non-converged state:
pathlines show what you woud expect, that the flow enters and flows around the chamber multiple times, and there's a vortex in the middle leading down to the exit 'plug-hole'.
Flow velocity contours at various planes over the model
