Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to obtain near field data of a electrical small antenna in reactive region? › Reply To: How to obtain near field data of a electrical small antenna in reactive region?
January 25, 2024 at 10:27 am
Hi MYK,
Thanks for posting your query.Â
The both the methods should give you similar results. Make sure that you are plotting fields at same region and at same frequency.
Using the near field setup, you can export the near field data. The steps are :
- Right-click the previously created near-field 'Sphere' or 'Line' or 'Rectangle' under 'Radiation' from Project Manager,
- Select 'Compute Max Parameters'
- The 'Max Field Data dialog box' appears for the selected near field 'Rectangle' as shown below.
- Click 'Export Fields', to save field data in .nfd or .csv file format.
Thanks
