Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FLUENT MultiPhase – floating point exception 6hrs into calculations › Reply To: FLUENT MultiPhase – floating point exception 6hrs into calculations
January 25, 2024 at 10:13 am
Hello Rob, I have made a copy of the simuation with the only change being the steady state. It failed within a minute or two with exactly the same errors. I realised that I had set the inlet gauge pressure, but not the outlet. I believe that may cause some issues with the simulation, as when I set the pressure to the same as the inlet, it started calculating!
Could you let me know if this could have been the cause of the problem with this simulation?
