Ansys Learning Forum Forums Discuss Simulation Electronics Characteristic mode analysis: how to plot antenna surface current for each mode? Reply To: Characteristic mode analysis: how to plot antenna surface current for each mode?
Praneeth
It is not required to define the excitations for characteristic mode analysis solution type. The post-processing of the modes analyzed by the tool is available through this edit sources option.
Best regards,
Praneeth.
