Ansys Learning Forum Forums Discuss Simulation Electronics Simulation cavity having a gap with HFSS Reply To: Simulation cavity having a gap with HFSS
DMARATHE
Hi Hien,
You can create a splitted cavities as I suggested earlier to create a separation/gap. This gap you need to fill either by using Box (Draw Box) of same size as gap or use Line feature to Draw the Lines connecting the vertices between two cavities on either end and then form a close surface/sheet. You will have to create four such faces to close the gap.
If you have access to Ansys Technical Support, please raise a service request and our support engineer will get in touch with you and clarify all the doubts.
Thanks.Â
