Ansys Learning Forum Forums Discuss Simulation Fluids Particles didn’t show up when using the DPM volume injection Reply To: Particles didn’t show up when using the DPM volume injection
Bill Hsu
Thanks for your suggestions, Rob! I’ve changed the particle residence time into the particle diameter, and the particles showed up in my model. However, after I ran my simulation (Numbers of timestep=5000, timestep size=0.05), the particles didn’t move. I already give a inlet air velocity with 2.5 m/s, and I don’t know why the particles didn’t move with flow (My assumption is one-way coupling). The following picture is the locations of 160 parcels, and the location is fixed no matter the time pass.
