Ansys Learning Forum Forums Discuss Simulation Photonics GDS_auto_export_test Reply To: GDS_auto_export_test
Amrita Pati
Hi Xie,
This is a bit strange. The same scripts are working for me. I have downloaded and tested since you started having the problem. From your screenshot I can tell that the required files:
Lumerical_GDS_autoexp_functions;
Lumerical_GDS_autoexp; are in the same directory.
Also, can you uncomment Line 74? We need Line 74 to be able to run the script successfully? Or is it also throwing the same error?
Amrita
