Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Issue with NVH setup › Reply To: Issue with NVH setup
January 24, 2024 at 7:57 pm
Hello Shiyun,
1. It is a meshing issue probably caused by several things. Could you delete mesh operation of CylindricalGap or make segments in Band? please check and modify geometries around Band and see if you can fix the issue.
2. Line is edge, that I think we do not need to select "as edge".
3 and 5. Could youd double check the field calculations for the torque and flux densities? I think you should get correct torque result in the field results.
4. Could you check if you run all the parameters?
Thanks.
HDLI
